thatoneguy
- Joined Feb 19, 2009
- 6,359
Remember to get video.
Smoke is good. Tires or components (preferably tires)
I'm thinking it out right now- How I can package it smaller, and also go to a less-biased RC circuit.There is no resistor between pin 7 and cap.
Intermittant use may work, you may only need a change of values
of the timing components to solve the problem. You can change these
values and still keep the same timing. A little thought now will
produce a better product.
Yes, it should be. Ceramic caps in that range will probably only
offered "non-polarized".
I'm out till tomorrow.
hit up my youtube channel. lolRemember to get video.
oops, I put diodes where the resistors should be. The diodes go inline to the relay, and around the relay. Is that all I'm missing?Hello,
I do not see the resistors from outputs of the 556's to the gates of the mosfets.
Also do I miss the back EMF diodes accross the relays coils.
Bertus
Let's try this again...Hello,
Bertus
Electricity is pretty tenacious. It will get through.too much resistance to be reliable,
Capacitor CHARGES through resistors.But is that too much resistance, to cause internal discharge of the capacitor (which would counteract charging, and make the actual period much longer)?
"Beware that electrolytic capacitors leak charge which substantially increases the time period if you are using a high value resistor - use the formula as only a very rough guide! "Capacitor CHARGES through resistors.
Capacitor DISCHARGES directly through pins 1 and 13 (pin 7 on 555).
there is no resistor between Pin 1 and Capacitor (or Pin 13 and capacitor).
What exactly is the difference? I agree, ordering a big batch of .1uF ceramic disks would make things a little easier. I read about putting a capacitor in parrallel to the input power to patch spikes, where does the other go?1. You need a .1uF cap for bypassing/decoupling
to ground placed as close to pin 14 (Vcc) as
possible to assure stable operation of the chip.
You will also need another larger (100-470uF)
cap accross the power rails to absorb any large
voltage spikes.
POWER SUPPLY BYPASSING or DECOUPLING GOOGLE it!!!.
2. You can replace all of them .05uF (.047 ordered)
to .1uF and operation will not change. This will
simplify your ordering.
see previous post3. I would try R/C combinations as follows:
For 1 sec timer: R=100K (1K-2.2K fixed + 200K pot)
C=10uF
For .5 sec timer R=100K (1K-2.2K fixed + 200K pot)
C=4.7uF
Double check the math before ordering.
I didn't know there was a difference4. I see you choice for 556 is a CMOS version (TLC556).
I didn't note the temp rating of your particular choice
but a little checking may get you a chip rated for
"higher operating temps" for literally a few cents more.
In your application the Low power consumption of the
CMOS chip itself is not necessary, A "standard" version
such as "LM556" or "NE556" will work just fine. SEEK OUT
DATASHEETS READ THEM. Compare and learn. The datasheet
for particular chip is attached. These datasheets are linked
right on the page you order from.
What about the inline protection diodes? The 4001's were the same price, so i just did a big batch of those instead of having 2 different kinds5. Diodes 1N4005 are a bit overkill 1N4001-1N4004 (or even 1N4148)
are acceptable for the protection diodes.
This one that worked, I probably cycled it 100 times in 10 minutes, before it blew up. And that was with the big caps.6. When you get this thing together either build a circuit to trigger
it from a timer continously (ON.....OFF....ON.....OFF) for a period
of time to see how long it lasts or put it in your everyday vehicle
and trigger it once in a while to see if it holds up in the automotive
enviroment (real live testing in a car).
This is one reason why "plenty of adjustment range" is necessary."Beware that electrolytic capacitors leak charge which substantially increases the time period if you are using a high value resistor - use the formula as only a very rough guide! "
is 20Kohms "too high" of a value?
So the regulator will take the 13.8~14.4 volt input, and reduce it to a constant 12VDC? This interests me, I agree, it helps alot (even with alternator and 2 optima's in parrallel, we're still getting vDrop at full power).With the 1 Meg Pot. at full resistance you get a 2 second delay before relay one engages and a tad over 4 seconds for the second relay.
At 1 ohm resistance on the Pot, you get .4 secs approx. 1st relay, and .8 secs approx for second relay.
Change caps c5 and c6 to get a different range.
The regulator is a low drop out, 12 volt fixed output, and I would suggest incorporating one for dependable operation of the circuit in the future. Linears' LT1086 is a good choice here.
This circuit can be adapted to a sensor input from an opamp with no problem, so a future automated time adaptive control could be developed.
I mean, what you posted takes up more room space-wise, than I have now (at least, once it's condensed). Right now, i'm only using one 556. So what does it gain me to use a second, if only one works?Mostly that it would be simple and easily made and maintained. using a 556 would make it fit in a matchbox, except for lights and controls.
