bassbindevil
- Joined Jan 23, 2014
- 680
So, it's biamped? That's unusual. Not surprising that the tweeter includes a blocking capacitor in case of wiring mistakes. What is more amazing is that it doesn't have any sort of line input (or output). DVD and MP3 players and Minidisc and computers and set-top boxes were things one could reasonably expect to connect to a sound system back in the misty past of 2004. Maybe even a phono preamp...
Anyway, through the magic of Google, I found the service manual:
https://elektrotanya.com/panasonic_sa-pm21e.pdf/download.html
There should be some place to interrupt the signal from the FM tuner and insert a selector switch and jack for line input. Like C202 and C402 (located on the Main PCB, to the lower left (west-southwest) of IC800), or the traces for pins 5 and 7 (of CN805) of the "tuner extent pcb". (I chose the tuner because the brain might mute the CD or tape when they're not playing.)
On the other hand... maybe you have a car FM modulator lying around, or can pick one up cheap? Then just wire it up to a 12V wall wart, which will be easier and safer than hacking the innards of this thing.
