Sound Level Monitor
mufcdanny
Joined Jul 9, 2009
5
Hey, I am new to this site.
I was wondering if anyone could help with my project, I had missed alot of my lessons due to illness and I can not find the solution in my notes. I have attached a file which I have to design. I just need help desining the circuit. I can work out the vaules for my self. I'm just not sure how to lay out the circuit.
Any help would be greatly appriacted.
Many Thanks
Dan
mufcdanny
Joined Jul 9, 2009
5
Im just struggling on how to design the circuit. I have a few caculations, but seeing where the companants go will help me calculate the rest. I'm having a serious mind blank.
Thanks
bertus
Joined Apr 5, 2008
22,278
Can you show the calculations?
As I understand you want to convert the calculations to a circuit.
Greetings,
mufcdanny
Joined Jul 9, 2009
5
I have misplaced my calculations but I had a input resistor of 1Kohm. Feedback resistor of 20k.
I have -68.5dB/v aswell. I will try to find them out.
I also have 20,000,000 gain bandwidth product wrote down.
Thanks for getting back to me
Any help is greatlty appreiacted
millwood
Joined Dec 31, 1969
0
you are asked to design a balanced preamp, with a frequency response up to 20khz, that when connected with a microphone (1kohm output impedance, and -54.5db/p sensitivity), it will trigger the led when the microphone sees 80dbl sound level.
simple as that, :).
mufcdanny
Joined Jul 9, 2009
5
I have sort of designed the pre amp. Im not sure about the component values, does anyone know what calculations I should be using so I can check. Thanks
Dan
