thanks for the advice!! did you mean a part of the main power supply or a separate power unit which was attached to the NECK card ? could you please locate it the service manual i have attached here?It's ripple in the PSU. The Trinitrons have a central caged PSU under the tube neck, slide that out and replace the smaller electros in it but not the very large one.
It's also worth cheking the marked points for the PSU voltages with your multimeter set to AC volts, as this will show ripple.
