Are you sure.?
How can you tell.?
Look...I do not have the diagram.
I am guessing here as most of the ones I get to repaire does not have fan's. OK only one did.
But I did not get 9 blinks ever. If it was between 2 and 7 I can point you to the right PCB.
And every schema does not indicate 9 blinks I am going with what I have as I think 9 blinks are saved for models with fans.
So I need you to make sure whether the tacho's are available. Without a diagram certain faults are very difficult to locate. As tht model is new to me and through internet guiding with un-experienced person is very difficult.
You need to make sure the fan are producing tacho signals..
If you can't the only way to make sure is by replacing them with new ones of the same type.
How can you tell.?
