How do I breadboard this device. I know that I connect pin 1 to a ttl signal across a resistor, the second pin to ground the 4th pin to ground its the 5th and 6th pin i am confused about. One picture syas "DC" off the 5th pin and I thought I had to connect that to the power supply but another diagram has pin 6 connected to a voltage load and Vout. Where do I connect the power? Off a load to pin 6? Or. do I connect pin 5 to ground and pin 6t and 4 to pullups?
