Question, wouldn't it be more efficient to use a cylindrical rod magnet (say, neodymium) instead of a soft steel rod as plunger for a solenoid magnet?
The way I understand it, current traveling through the solenoid creates a magnetic field, which in turn attracts inside the rod sitting on the outside. But wouldn't the force (and efficiency) be much greater if a rod magnet were used instead? That way both the solenoid's field and the magnet's would interact, instead of just the iron rod being magnetized by the solenoid's field alone.
