I had no luck in tracing that number. If you have an analog ohm meter that uses a 6V to 9V battery
on high ohm scale the leads on the OSI can be identified. If one pair reads open in one direction & around 10k reversed, that is the LED; other pair might read almost open either way, that is transistor.
If 10.1 is cm should be fine. I would reinforce the area around connecting rod attachment.
