Soldering station broken. Worth having it fixed? Should I buy a new/better one?
amundsen
Joined Aug 27, 2015
30
I have a Velleman VTSS20 soldering station (48W/150° to 450° C). It costed something like 80€. It broke yesterday after three years of use. Suddently the temperature indicator (LEDs) displayed the minimal possible temperature and the temperature dropped. I switched the unit off. Later I wanted to switch it on again but all the LEDs were off. So I checked the fuse but it was OK.
I have asked the maker for a schematics but I am not sure to get it at all. Anyway as I have no other soldering station, I'll probably have to make it fixed by another person or through the reseller.
The question is: is it worth having it fixed, or it or should I rather buy a new one? What's your experience with this model or brand and with other ones?
The point is I am more an hobbyist than a professional, I do not use my station everyday, but I need a reliable unit whatsoever. Moreover, I need it within a week or two. I don't know how long it will take if I want to have it fixed by Velleman. Any idea?
Thank you in advance.
MrAl
Joined Jun 17, 2014
11,494
Soldering stations can be purchased a lot cheaper these days so probably buying a new one would be better than getting the old one fixed, unless you can fix it yourself and then that is probably cheaper.
If you could take some pictures of the inside we can take a look and see how difficult it might be to repair it.
Also, it could be as simple as the iron handle itself that went bad not the control unit.
If you need an iron right away you could pick up a cheap one and use that until you get the good one fixed.
BTW if you buy a new station you can get a hot air tool with it for doing SMD packages or other.
recklessrog
Joined May 23, 2013
985
The iron is used by several different soldering stations and is available as a replacement cheaply on amazon etc. (just type replacement 24 V 48 W soldering iron) It contains a thermistor and a heating element and if either fail will cause the controller to act strangely. unplug the iron from the controller and measure resistance between the pins between pins 1 and 4 you should have approx 3 to 5 ohms, and between 2 and 3 about 2 ohms measured cold.
Some come with a round plug but it is easy to fit your original.
amundsen
Joined Aug 27, 2015
30
Is it normal that there's even not a single LED lit on the temperature display when the unit is switched on?
amundsen
Joined Aug 27, 2015
30
My bad. I had pushed the fuse too far when I had checked it. Now the unit is clearly on with one LED lit. So as recklessrog suggested it is probably the iron itself which is broken (the display flickers steadily when there's no iron plugged). I would like to measure the resistance as suggested before looking for a replacement iron, however the connector has 5 pins and not 4 (actually it's a good old DIN connector).
dannyf
Joined Sep 13, 2015
2,197
Depends on your skills and financial resources. First of all, they tend to be pretty inexpensive, especially those soldering handles with built-in temp control.
2ndly, they are fairly simple. I have made quite a few with just a mcu + mosfet + laptop power supply and they worked quite well. Fully analog solution is also possible as well. If you are handy that's another way to go.
takao21203
Joined Apr 28, 2012
3,702
I had this problem recently needed to do a job for customer so I bought a new one
85 euro only one useful tip.
Still have the transformer/pcb, maybe I get iron for it since I have spare tips which were expensive.
amundsen
Joined Aug 27, 2015
30
I think one can buy tips from other manufacturers (fixpoint fom instance) as this Velleman station seem to be a clone of some other devices (Solomon?). However the connector might be different on models from other brands.
Besides the official Velleman iron, I have ordered a 3€ iron from eBay. It has a different connector but I think I could recycle the defective iron's connector.
markzz
Joined May 25, 2016
16
Its good you bought a new soldering station.
I will just add this. I am trying to score a Power Fist iron from Princess Auto which is 5W to 60W adjustable iron for $9.99 CAD on sale. Normally its $23. Princess Auto is like your Harbor Freight in the USA. Not sure of an equivelant in the UK/Europe. Only problem is they got fat tips.
Those Hakko's are nice.
