solar panel project
Kaiser Ed Bayawa
Joined Mar 19, 2015
64
I want to build a solar panel that can supply the whole house. I already have 13 plates 12 volt battery from my uncles car. I am planning to buy a solar panel. Can anyone advise me what should I do in order for this project to be successful? Please.. any comments help alot. Thank You.
blocco a spirale
Joined Jun 18, 2008
1,546
Calculate how much power your house consumes and for how long. This will tell you how many amp/hours you require and from that you can estimate the size of solar panel and battery you need.
But, if all you have is an old car battery to charge; a 50-100W panel is probably all that you could use. You also need a charge controller and an inverter.
18,105
I suggest starting small – maybe some LED lighting instead of a whole house – so that you learn what is involved. Beginners tend to overestimate what a solar panel can do, and underestimate the cost and complexity of an integrated system large enough for a home. The small amount you spend on a small unit will not be wasted, when your experience helps you build the bigger system properly.
A system based on a single car battery is a "small" system. It would not power more than some lighting. No appliances.
Kaiser Ed Bayawa
Joined Mar 19, 2015
64
thank you sir
Kaiser Ed Bayawa
Joined Mar 19, 2015
64
thank you sir
ian field
Joined Oct 27, 2012
6,536
AFAIK: by the time you get into inverters, most countries have building regs that require all work be done by a certificated electrician.
12,139
If you goal is to collect energy during daylight, and have enough stored energy to run your house all night, you are going to need dozens of car batteries. "...supply the whole house." needs a lot of definition. Refrigerators are very hunger. More for an electric dryer, more for an air conditioner, and more for an electric furnace.
Roderick Young
Joined Feb 22, 2015
408
Much depends on the size of the house. A system built on a single car battery like you describe is enough for some places in third world countries, but remember that all they are running is maybe a couple lights and a radio. If you have a first world house, a single battery like that won't be enough. It would be enough for some LED lighting, and maybe a laptop (not a gaming laptop) for an hour.
The kind of system that is cost effective for a whole house generally does not use batteries at all. That takes several hundred square feet of solar panels, and is usually not a do-it-yourself job, although it is legal to self-install in places like California.
