Good Morning,
As per subj, I have a problem with wiring/controlling a YL90L-4 electric motor on my older CT043 Craftex lathe. I've taken a bunch of pictures and done lots of testing, the results of which I'll post below. The government agency that I bought if from laid it down on its back and mashed the connections totally. None of the wires were labelled so I applied arbitrary lablels. How do I successfully wire this motor to my forward and reverse lathe switch. Please note that this is a made in China motor so where the standard voltage is 220v, so not both sides to a neutral, just 220v across 2 wires. As you can probably see, I'm not an electrical guy so you'll have to be explicit with any recommendations.
There are 3 Power Control wires (plus a ground to the motor casing) coming from the fwd/rev switch to the motor. I've labelled them as follows (see photo 1):
Power Control-Black1 (PC-B1);
Power Control-Black2 (PC-B2);
Power Control-Black3 (PC-B3).
I've tested them with power to the machine. Results are as follows:
There is 220v between PC-B1 and PC-B2 in forward and reverse;
There is 220v between PC-B1 and PC-B3 in reverse (0v in forward);
There is 220v between PC-B2 and PC-B3 in forward (0v in reverse).
I took apart the motor and traced and tested the wires. I've labelled the wires as Motor Top (MT) and Motor Bottom (MB), based on which hole in the casing that they emerge from, with color code as per above. Results are as follows:
MT-R1 has continuity with MB-R1 with a resistance of .9 ohms (Winding 1);
MT-R2 has continuity with MB-R2 with a resistance of .9 ohms (Winding 2);
MT-Black enters the case and goes directly to one side of the centrifugal switch, then to one pole of the running capacitor;
Other side of centrifugal switch (switch closed for start/open for run) goes to one pole of the starting capacitor;
MB-Blue enters case and goes to second pole of both capacitors (they run in parallel);
Capacitance between MT-Black and MB-Blue with centrifugal switch in starting position (closed) is 185 micro farads (which is in the ballpark as the starting capacitor is 150 micro farads and the running capacitor is 20 micro farads).
I connected the motor as follows:
PC-B1 to MT-R1 and MT-Black
PC-B2 to MT-R2 and MB-Blue
PC-B3 to MB-R1 and MB-R2
The motor will run in forward and reverse for 3 to 4 seconds before tripping the internal switch (8.5 amp breaker). All fuses have been checked serviceable. No smell of burning. Panel breaker does not trip. Put a clamp on ammeter on PC wire and measured 13.5 amps so the internal breaker is working as advertised.
Any help would be much appreciated.
