Single phase ac motor speed controller
RASHEDTAMIM
Joined Mar 15, 2018
Which 3 method will be easy?
1.Stator voltage control
2.Frequency control
3.Rotor voltage control
4.current control
5.Voltage frequency control
6.vectrol control
qrb14143
Joined Mar 6, 2017
112
I'm not sure that the six options you list are necessarily different. AC induction machine control could be broadly split into two categories, Scalar Control and Vector Control.
Scalar control is more straight forward and can be implemented using a simple "v over f control scheme". Vector control is somewhat more complicated. Both will require manipulation of the input voltages so you could argue they were both voltage/frequency control.
MaxHeadRoom
Joined Jul 18, 2013
30,815
What is the nature of the motor? Shaded pole? PSC? Start & run cap?
1ph induction motors are notorious for very poor for variable speed control .
How do you intend using rotor voltage control if it is an induction motor?
Max.
