I am trying to set up a remote start for my 99 Tahoe. I have it mostly figured out and am stuck on one last part. I need to make a circuit that controls a Latching relay with a single momentary push button. I want it to work like an impulse relay, but don't want to fork out $25 for each relay. The relays could either be single coil (polarity change) or dual-coil (separate signals) I believe a 555 timer or a decade counter would work to control the relay, but I am not sure how to hook one up to the circuit. Thanks.
Also, a alternate action push button wont work in this case because the circuit is getting multiple pulses from different switches, including a remote control keyfob output. I used on a bypass circuit I made to complement the circuit I am working on, but wont work for the ignition switch. I will post my initial schematics later if needed for explanation.
