I have been experimenting with building a voltage switch using the simple comparator circuit below.
It simply measures the supply voltage and turns on the relay when it gets up to 10 volts, then off again when it drops back down to around 9 volts.
The problem I am encountering is that when the supply is initially applied, regardless of whether it is 8 volts or 11 volts, the relay is triggered for about 500ms before the circuit settles down to correct operation, other than that it works perfectly.
Are my capacitor values wrong, or am I missing something as I can't understand why the circuit is not working as expected on initial turn on?
Thanks,
Mark.
Thanks,
Mark.
