You didn't carry your MOS over to civilian life? Why not?My problem is that I used to know this stuff. I did circuit card repair in the military, but that was a couple years ago and I haven't really messed with any of it since then
Did you move your LED Pods out of the Collectors of the NPNs and into the Drain circuit of the FETs as shown? If so, did you remember to connect one end of both 470 Ohm resistors to the collectors?Ok went after the 1M ohm resistors. Had the circuit hooked up with the 100K resistors tho and it didn't even come on.
on yours there bill, what are the transistors?
Thanks for your Service, bro.My problem is that I used to know this stuff. I did circuit card repair in the military, but that was a couple years ago and I haven't really messed with any of it since then
I did move the LED Pods.Did you move your LED Pods out of the Collectors of the NPNs and into the Drain circuit of the FETs as shown? If so, did you remember to connect one end of both 470 Ohm resistors to the collectors?
Ouch! You've got a couple of things wrong there:OK, here is what I have hooked up.
The LED's are those pods.
Yes Sgt. that's why I added a voltage divider but I failed to post the schematic because.... because I'm brain dead! LED's in series with R9 & R10 would also help but I don't think he needs them.As you'll notice from the yellow plot below the schematic, Q2's collector voltage spends about half the time at 7.3v, the other half at nearly 12v. This is why you can't successfully drive the gate of a MOSFET directly from the collectors of Q1 or Q2.
That's the thing about this particular astable MV; the collectors of Q1/Q2 do momentarily go to nearly 0v. However, they spend most of their time at about Vcc/2 and Vcc-2v.Here's a complete schematic that I spiced. Note the addition of R9 & R10 and the change in R9 & R10. You may have to play with these values but I doubt it. Also note that my spice run indicates nearly 1A flowing through each LEDPOD when they're on. You will not pull 1A though. I spiced it this way to demonstrate that those FETs can power a bunch of those LEDPODs if necessary. Any questions, just ask.
The omission of a voltage divider (R1 & R10) and (R2 & R9) was a screw up on my part. I should have realized the the collectors of Q1 & Q2 would not pull to zero. Let us know if you understand what they're for. Here's an exercise for you:
Find the value (using Ohms Law) of the max and min Gate to Source voltages. This can be calculated by looking at the max and min collector voltages of Q1 & Q2 as shown in the graph.
