Excellent example.Here is an example in impedance matching.
Suppose you built an audio amplifier with an output impedance of 5kΩ and wanted to connect this to an 8Ω speaker. You can use an audio matching transformer with
turns ratio = sqrt(5000/8) = 25
Suppose you wanted 500mW output = 1/2 W.
2V output would give 2 x 2 / 8 = 1/2 W.
To get 2V output at the speaker your amplifier would have to generate 2 x 25 = 50V output!
Power generated at the 5kΩ output = 50 x 50 /5000 = 1/2 W
same as power at the speaker, i.e. maximum power transferred.
Yes the preamp can amplify a small voltage, but the Input impedance of the pre-amp must be at least equal to but preferably higher than the impedance of the microphone....
The pre-amp can take a small microphone voltage and it get amplified, the input impedance beeing relatively low compared to the mic impedance? And does it opposingly draw more current from the mic, but see little voltage from the mic? Basically like transformers do due to the conservation of energy.
Because the little voltage the mic produces will stay with the mic since higher resistance series connections hog the voltage in a voltage divider when the ratio is a large enough difference, correct? The current will be higher on the input since a parallel resistor is used from input to ground and the lower resistance hogs most of the current due to the ratio aswell. So current and voltage are sort of inversed in these type of circuits since inputs use a parallel resistor from input to ground but this same shunt resistor is in series with the mic? Something like that?Yes the preamp can amplify a small voltage, but the Input impedance of the pre-amp must be at least equal to but preferably higher than the impedance of the microphone.
As in the bridging scenario above, 600 ohms source can connect to 10K line input, but you cannot connect a 10K source to a 600 ohm input without out 'loading down' or losing most of the signal.
Why do you think that would be?
by Jake Hertz
by Jake Hertz
by Aaron Carman
