Hello.
I have a wire, Wire ABC, with current going through it. When Wire DEF comes into contact with wire ABC, I want the current to no longer run through the BC part of Wire ABC. Could I possibly run wire DEF into some sort of "ground" so that the current through wire ABC runs through DEF into the ground, and doesn't continue its path along wire ABC?
Does that work? Is my concept of ground not correct?
I'm used to "ground" being the zero-point of nodal analysis, and in that sense, my idea makes no sense.
What am I doing? should I just make the resistance of wire ABC very high and DEF very low?
Here's a picture because I don't feel that I'm being very clear:
