OK, I figured out what they meant ... look for their other auctions of the similar type; the specifications are on the other auctions, not on the package that you receive.
Here is what I found:
Choice #1B: 5mm Red, 4,000mcd
Product Label: 100x FCB Red 5mm Oval Ultra Bright
Package Description: 100 pcs 5mm Red LED 4000mcd
Emitted Color: Red
Size (mm): 5mm
Lens Color: Water Clear
Peak Wave Length (nm): 625 - 630
Static Sense: No
Forward Voltage (V): 1.9 - 2.1
View Angle: 5 - 25°
Luminous Intensity (mcd): 3500 - 4000
Maximum Current:20mA Continuous, 50mA peak for 10% Pulse Width
Item Net Weight:75g / 2.7oz
Choice #2B: 5mm White, 15k to 17,000mcd
Product Label:100 pcs 5mm White LED 17000mcd
Emitted Color:White
Size (mm):5mm
Lens Color:Water Clear
Peak Wave Length (nm):N/A
Static Sense: Yes
Forward Voltage (V):3.0 - 3.2
View Angle:5 - 25°
Luminous Intensity (mcd):15000 - 17000
Choice #3B: 5mm Blue, 6,000mcd
Product Label: FCB 100x Blue LED 5mm Ultra Bright
Product Description: 100 pcs 5mm Blue LED 6000mcd
Emitted Color: Blue
Size (mm): 5mm
Peak Wave Length (nm): 460 -470
Static Sense :Yes
Forward Voltage (V):3.2 - 3.4
View Angle: 5 - 25°
Luminous Intensity (mcd): 5000 - 6000
Maximum Current: 20mA Continuous, 50mA peak for 10% Pulse Width
Item Net Weight: 75g / 2.7oz
Emitted Color: Red
Size (mm): 5mm
Static Sense: No
View Angle: 5 - 25°
Emitted Color:White
Size (mm):5mm
Static Sense: Yes
View Angle:5 - 25°
Emitted Color: Blue
Size (mm): 5mm
Static Sense :Yes
View Angle: 5 - 25°
