Our microwave in our Airstream is about 4 years old, but actual usage on the unit is maybe at most 30 hours. This season I noticed one of the segments in the clock/cook time was out... opened unit, typical multiplexed display via a controller. Since one segment is out, it isn't a row/column resistor/path issue or poor solder joint as every other part of the display works. I am thinking the segment mask within the display has opened or fractured from temp/heat/vibration..... vibration would be my primary guess of the failure cause.
I've tried to search for the display part number and it comes up with house listings LOL...…. MLS and 5 digits usually is how houses in the USA are listed (not sure about overseas). So even factoring down with LED, display and other keywords, not getting any result on the display itself.
I also think that the led display is "universal" as the PCB seems to be used in many brands and configured accordingly.... and they use a "mask" to create the needed icons for whatever series or NRE vendor that buys the product from what looks like mIdea... which I "think" is a Chinese manufacturer.
Searching for the main PCB is a crap shoot because the part numbers are very close but not right on..... I think this is MD1001LE which Google does bring back many results, but the LE is missing, usually LD, or other variants.
If the display is the same between non matching PCBs, I have no issue transplanting it and then remasking it using the original overlay, which I assume from the picture can be separated from the display and transplanted to make it right.
The model number of the microwave is: Contoure rv-200s-con.
So the question is, anyone have an idea where I may be able to find the replacement for the LED display? The rest of the PCB is 100%, just starting to drop segments... others on forums who have this microwave say this is the beginning of the end for the display as once one goes, they saw more go over time to the point it was unreadable for the time etc.
I just can't seem to find the part number for the display itself, I don't think that it is a special OEM since the display is laser stamped/coded.... but I could be wrong.
Any thoughts?
Regards,
Chris
Any thoughts?
Regards,
Chris
