Are you saying that i may be over driving them? In the convo from earlier. Thats one possibility it seems. I asked the tech and he said there is no way to know ultimately unless i get ahold of the specs and he does not know how to do that.168mA is typical.
May be that PSU's switching frequency is giving you the fatigue
would a 6volt battery in between the charger and leds' work?OK, so you have ripple voltage at 7.KHz. What is the level of it...50mV P-P? If you applied this level voltage to any LED it wont even light up. Any level ripple riding on top of your DC will have no effect. The ripple frequency doesn't matter either. Take a fluorescent light for example. They flicker at 60Hz. Can you see it....NO. While LED's will operate at high frequency currents into the MHz region, eyesight cannot respond this fast because of a physical property known as permanence of vision.
What are you talking aboutwould a 6volt battery in between the charger and leds' work?
i have 12volt led strip lighting and there was a tormenting flicker as the generating stations power fluctuated between 96vac to 122 vac. so i placed a 12v 7ah battery after the transformer and eliminated the flicker. these lights are in a tavern and run 24/7. they are indirect light under the bar top 64' long.What are you talking about
This is so good to read. i love the sound of ripple not invading my LEDs. these lights have grown on me and I find that I want to use them in other rooms that I spend a lot of time in.OK, so you have ripple voltage at 7.KHz. What is the level of it...50mV P-P? If you applied this level voltage to any LED it wont even light up. Any level ripple riding on top of your DC will have no effect. The ripple frequency doesn't matter either. Take a fluorescent light for example. They flicker at 60Hz. Can you see it....NO. While LED's will operate at high frequency currents into the MHz region, eyesight cannot respond this fast because of a physical property known as permanence of vision.
by Aaron Carman
by Jake Hertz
by Jake Hertz
