That's a very good point, and surely good enough for me to forget about any kind of throttle position signal fudging. I will talk to the LS1tech / V8RX7 guys and see if there's a safer way of telling the ECU to raise throttle, or otherwise tell it that AC is ON. In the older LS1 engines it was all easier because the ECU did AC as well, but on the LS2 engines, the AC has been moved to the Body Control Module (secondary, body/chassis ECU) which I don't have, and in fact nobody ever has when they do these engine swaps.You have to ask yourself, "What might happen if my circuit failed?"
Toyota did not do this enough, and as a result, many people have been injured or killed when their engines suddenly went WOT for no apparent reason.
For obvious reasons, we are reluctant to discuss circuits that even monitor existing engine control signals, as malfunctions of circuits may result in safety issues.
That's to make it easier on the person who's creating the simulation.Nope, I'm struggling. I found a quad comparator in LTSpice - the LT1721 (http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1154,C1004,C1012,P1707 ), but there are two things I don't understand. Firstly, it just comes up as a basic comparator symbol in LTSpice.. it certainly doesn't show four inputs.
There are some comparators that do have built-in voltage references. However, they are not hard to make using resistors or a pot, and a small cap.Second, whist the datasheet does indeed list four separate inputs (and another four inverting of the same), I don't see any kind of "vRef" pins. I was sort of hoping for 4xvRef and 4xInput, and that the chip would compare input against vRef, for each of the four inputs.
See the post I just made.I guess it's just not that simple is it ? Any hints?
You're using REALLY high values for your resistor divider network, and no stabilization cap.
Usually, you'd want somewhere around 0.1mA to 2mA current flow through the resistor network, so that it doesn't take too long to establish the reference voltage, but at the same time it doesn't use a lot of power. 1K per 1v of Vcc usually works pretty well.
See the attached.
You can download the simulation to your LTSpiceIV directory and play with it.Fab, that looks great, and I'm really pleased that I understand it too
Good question. Now why would I have done that?Why 2.4k resistors and not 2.5k ?
Thanks very much. I have bookmarked those sites, and have just put 2500Ohms into the resistor calculator. I hadn't considered what running resistors in parallel would achieve. Interesting.You can download the simulation to your LTSpiceIV directory and play with it.
Because 2.5k is not a standard value of resistance!
Standard E24 resistors jump right from 2.4k to 2.7k.
Here's a table of standard resistance values:
http://www.logwell.com/tech/components/resistor_values.html
Bookmark that page.
Now you say to yourself, "That silly Wook; he could put any value he wanted to in there!"
Well, that is true. However, frequently people want to actually build something that was the result of having been prototyped and evaluated using SPICE. So, why would you start out building a simulation using values that are not standard or obtainable?
If you stick with standard values in your simulation, going from a simulation to a breadboard circuit will be a whole bunch easier. Otherwise, to get 2.5k you would have to use combinations of resistors in series and/or parallel.
Speaking of which, here's a very handy online calculator for doing just that:
http://www.qsl.net/in3otd/parallr.html
Bookmark that page too. Try it out; select E24 values, and then enter 2500 for the resistance. It will show you various combinations of resistors in series and parallel to get close.
However, since I started off with standard values - it's unnecessary.
