Then I guess it's not accurate.You may want to rephrase that, as it's not accurate as stated.
RETRACTION:
One issue I see is that you have npn transistors upstream of the motor. those are only meant to switch ground.
If you are reffering to the ones up the top and bottom the circuit will be based on a breadboard the are just going to be connected to the top and bottom rail.You have conductors that appear to make connections to air. Since there's no antennas in your project this is not acceptable.
I counted four terminals on your motor. So no, it's not less confusing.Did my previous message make my circuit less confusing or not?
Do you have time to explain?You are correct though that NPN's used as he has would be problematic. It's past 1AM here so I need to hit the sack. Tomorrow I'll explain my statement.
OK, the problem with your statement is that it's not a matter of "up stream" or down stream. For the record, what you're calling "up stream" we call "high side switching" but that's not the issue either. It's the statement in bold that's inaccurate. I've attached a Schematic which uses a negative high side. As you can see.. the load... not the transistor is connected to ground. While we generally accept GND to be negative, it doesn't have to be.Do you have time to explain?
Yes John, I'm beginning to think that I have suppressed masochistic tendencies. The circuit that you posted, along with that very low current motor, would be ideal for him... if he could obtain one. One of benefits of that little motor and the attendant series resistors are that he wouldn't need any limit switching when the gate reaches its end of travel. The stall current will be so low that it's not necessary to detect it. He could simply time how long it takes for the gate to traverse and program the output off a few seconds after that. Heck, because it draws so little, it could probably stay stalled for months without hurting it.I'm finding this thread too frustrating to contribute to. KiwiKid, you just aren't being clear on what you need to do and what the constraints are.
That's NOT what your print shows!!The motor only needs two terminals a - and a +, I'll just solder two terminals to each end which I can do. Why is this a problem?
The solutions to this topic has been posted more than once. I suggest that you re-read from the beginning. I would also think that if your instructor has given you guys a project like this you would be at a level that you would know that you need a base resistor.Hey KiwiKid, i am currently doing the same course as you.
For your Circuit Diagram, This 'may' work
http://imageshack.us/photo/my-images/192/circuitt.jpg
I'm on the precipice of core meltdown!!!
I've got a better idea. After I finish installing a new upper blade guide on my bandsaw I'm heading out for some cold brewskees. Come to think of it, I probably will have a rare bacon cheese burger too!Hey CDRIVE.
Go fix a sloppyhamburger
by Jeff Child
by Jake Hertz
by Aaron Carman
