Resistance + LED works on breakboard not on stripboard?
Endless Paradox
Joined Mar 16, 2018
7
Like the title says why?
Here are some pictures if it helps
I tried removing them from the breakboard to the stripboard like 3 times.I tried soldering all the cables even with the batteries cable.I tried without soldering.I tried putting the battery leads directly on the coppertrack.It refuses to work in the stripboard why?
oz93666
Joined Sep 7, 2010
739
lol ...you couldn't make that up ... I knew what a breadboard was , but a breakboard was a new one ... I don't think it matters too much that everything is soldered to the same copper strip , none of the solder contacts look good .. the solder must wet the copper strip.
Breadboard
