where can i find that?Can you post the simulation file?
In your hard disk. The file is "your_project_name.pdsprj" (filename extension - .pdsprj)do you mean this?
Are Vcc and Vee defined for your simulation?
They must be between 5 and 20 Volts.
If the supply voltage are lower that 5 Volts, there will be no output swing possible:
Bertus
that does the trickTry to change C2 to 2.2μF or more and C3 tp 470nF or more.
by Duane Benson
by Robert Keim
by Aaron Carman
by Duane Benson
