You have to check the manual for defaults, but retched is right: don't count on the defaults. It's not uncommon for there to be some code path that looks sort of like a reset, but doesn't actually reset the hardware. In that case, your peripherals will be set up however they were before the pseudo-reset happened.uC pins are by default output right? no need to initialize them as anything?
MOV P1,#00h;
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
