[Edit: I looked at the resistor again. It looks like I fried it. That doesn't show up in the picture. Maybe it happened shortly after the picture. Anyway, the resistor is where I am pointing with the pencil, so I was partly right. Can you suggest how to resolve this problem?]
I'm new to electronics, but when I have a software problem I usually post to a forum. Now I have an electronics hardware problem, I hope the same works.
I'm doing Experiment #7 in "Make: Electronics", "Relay Driven LED's". I changed some of the connections to soldered connections, because doing it all with alligator clips is extremely difficult. I'm using a hacked AC to DC converter as a power supply. It's set for 12V.
I saw a light go on and I thought it was working. Now, when I connect the items I'm pointing to in the picture below it gets very hot and I smelled a little smoke. Can you help me to fix this problem by looking at the pictures below, or otherwise offer any advice.
Slide Show
http://s1232.photobucket.com/user/webmanoffesto/slideshow/Make_Elec_Exp_07
Other postings I found online agreed that doing it all with alligator clips is not a good idea. One guy converted it to a breadboard project, but that's beyond me.
Thanks
Slide Show
Thanks
