So I’m in the beginning stages of building a powered controller for heating blankets for nitrous oxide bottles. It’s a simple design that uses a drill battery 18v to be exact along with two powered switches. The circuit runs through a 25amp circuit breaker which feeds the switch and 24v relay. Then out to the heater. From time to time I get chatter in the relay. What could be the cause and what could be a simple fix? I’m using 30 as the main power, 86 pin as switched 85 as ground and 87 as feed. I’ve read about the use of a capacitor but I’m getting mixed directions on proper connections of the capacitor and which capacitor to use. Forgive me as I’m a hobbyist that isn’t very versed in this world but has excellent understanding of how these simple devices should work. I’ve been told by a few others this is normal but I don’t think so. Thanks in advance.
