I built a battery powered device that requires the use of two different voltages. It uses 3.3V to power general electronics components, at very low power, no more than 100 µA or so. And16 volts to power a valve actuator solenoid.
For this purpose, I found an excellent 3.3V regulator that draws a ridiculously low amount of power when idle, about 0.8 µA. And I'm quite happy with it. The problem is that this regulator accepts a maximum input voltage of 7V. And so I decided to arrange the array of 10 batteries according to the following schematic:
What makes me unhappy, though, is pretty obvious. The lower 4 batteries (which deliver 1.6V each when new) will deplete faster than the upper 6 batteries. This because the electronics draws a continuous amount of current, while the solenoid is only powered sporadically.
I would very much like to find a way to regulate the entire 16V array down to 3.3V, while also maintaining the minimum possible power draw form the regulator itself. I've already browsed through dozens of component candidates and so far I haven't found a single one that meets my requirements. Any ideas?
