Yes, the simulated components are highly ideal, as I pride myself with getting just the "best" components I can get. *laughs* No, just kidding I knew about the different models, I just hadn't applied the knowledge to the simulation.Keep in mind that you are likely using "ideal" capacitors and "ideal" inductors, which don't exist in the real world.
Yikes! 85 Ohms will totally destroy my output voltage, not to take into account two of themAdd some parasitics to the inductors, too. 56 turns of AWG20 on a 31mm*18mm*6.3mm iron toroid would take about 100 inches (2.5 meters) of wire, for roughly 85m Ohms.
This is what I get for buying stuff before I know what I need, I kinda wish I had bought a 12v transformer instead of the 9v I now have
Oh well, the theory about the inductors have been very interesting atleast, if not applied to this project it will most probably come in handy in a future project.
About C4, I get that it's interfering with the regulation, the way I understood it was that it lead any ripple(and sharp changes in regulation) directly to ground. This is a good thing for ripple, a little bit bad when it comes to sharp regulation changes.To improve load and line regulation to a fixed output 9 Volt regulator, try the following...
- Add 1 ohm...limit inrush current. Check!.
- Get rid of C4 See below.
- Get rid of D4 and replace with a zener. Check!
- Replace C2 with a 220u cap. Check!
- Use 10u to 100u as the output filter. Check!
- Put 0.1u across R2 for stability if required. We'll see
But I'm wondering if the good stuff(very little ripple) is outweighing the bad stuff(slow reaction to regulation), I have not seen the latter in my simulations, but then again, in simulation everything is "stable"(ie. not changing). If I were to remove C4, I would have to compensate greatly in the "main" filter, probably ending up with 4 or more 4700uF caps(not that it's a problem, I'm just trying to be sofisticated about the ripple ).
I have made a chart showing the difference in ripple with different C4 values over a varying load, this is with 2x4700uF caps as the main filter(and every cap is now using a model with more real behavior). It shows very clearly that C4 is helping a lot in ripple rejection, but again, I feel I need more information about the ill effects before changing it out.
I should probably say that the load requirement for this supply will probably not exceed 100mA, as I am planning it as a supply for my guitar effect pedals.
My first incarnation on a breadboard is actually doing that duty already, and I have discovered that I might need a short protection, the 2n3904s I'm using as output stage(while waiting for bigger ones from mouser) is really not living more than miliseconds if I happen to short the output, so I'm fearing the worst when I replace them Atleast the transistor-god is happy with this much sacrifice
Will do, am and same to everyone elseHave Fun
Kolbjørn
