Why difficult? It's just like a HV spark generator but in reverse. As long as it's got enough turns in total and roughly the right turns ratio.
Say 1000v : 12v is 1000t : 12t
but with expected low efficiency you need a higher output turns number like
1000t : 30t
then 1000t is a pain to wind so I would start with something like 300t : 10t or so and see what happens.
After that it is a matter of experimenting, and fortunately with low output turns like 10 it's pretty trivial to add or subtract a few turns on the output.
For experimenting I'd just hook it up and put say a 1k resistor on the output winding, then get the input current sparking and look at the output waveform on the 'scope. That should give an idea of how much output voltage and current should be available and turns can be tweaked accordingly.
1000t : 30t
