Hey guys.
For my question, consider, if you will, the simple schematic in the following link:
http://www.555-timer-circuits.com/flashing-led.html
If a 9VDC voltage is applied to the circuit, as per the diagram, is the voltage entering pins 4 and 8 also 9 volts or is the voltage reduced / affected by the two resistors in series?
