Hi All,
So I have (with much help) created a DC boost circuit discussed here http://forum.allaboutcircuits.com/threads/dc-buck-boost.116393.
This is my circuit
So I have two multimeters. I have a UEI brand DM383B and also a GE2524. Both have settings and probe locations for measuring DC amperes of up to 10A. I understand that I should disconnect the positive connection from supply to load. Connect my meter's positive probe to the now available supply positive and then the negative meter probe to the positive load lead. Leaving the negative supply to negative load as is (fully connected with nothing between). I get a zero on both meters and the load does not become active. What in the world is going on?
Thank You, John
This is my circuit
Thank You, John
