Thank you! On both counts!A small fan strategically placed will disperse solder fumes away from your face. All you need is a slight breeze.
If you're not trying to save the IC, often you can cut all the leads close to the body then desolder one pin at a time.
I was afraid any fan blowing over the solder would make the solder difficult to flow. Some areas of the board were almost impossible to get the solder to flow right.
As for the ICs, if I can cut the pins, I'll do that.
Thanks again!
