Calculate the voltage across the inductors
total current
total current
Hi,Calculate the voltage across the inductors
total current
About the only criteria that would make sense, in the lack of anything specific, would be if the resistive component is more or less than the reactive component (which is equivalent to saying if the impedance angle is less than or greater than 45 degrees (in magnitude).You can simulate the circuit. This way you will know answers to 5 and 7. This will let you check your answers, if you do the math.
To everyone else. I am kinda curious about number six. What are the criteria to decide if the circuit is predominantly resistive or inductive?
So find total impedance of the circuit, it will be complex value, find the angle from the complex value?About the only criteria that would make sense, in the lack of anything specific, would be if the resistive component is more or less than the reactive component (which is equivalent to saying if the impedance angle is less than or greater than 45 degrees (in magnitude).
That would be one way.So find total impedance of the circuit, it will be complex value, find the angle from the complex value?
