mixed_signal
- Joined Dec 5, 2009
- 22
[EDIT: I wasn't thinking clearly when first adding this post... corrected now.]You have a misconception about what a current regulator does. The whole point is that it will drop ALL the voltage in the circuit that isn't taken up by the other components.
That's correct. In the LM317 the regulator acts to hold its internal reference voltage (usually a bandgap reference voltage of 1.2 to 1.25V) across Vout to Vadj by adjusting the output current.
To understand the power dissipation in the LM317,
- Assume the target/desired current is fed to the load
- If the load voltage ends up being less than the max voltage possible for regulation at the LM317 output (approx. Vin - 3V?), then the LM317 will have the excess voltage across Vin to Vout. Then LM317 power is (Vin-Vout)*Iload.
- If not, then it's not regulating and you're trying to put too much current into the load.
See, for example, the applications in figures 4 and 9 in the TI LM317 datasheet: http://www.ti.com/lit/ds/symlink/lm317.pdf
Also, a few other related links:
http://users.telenet.be/davshomepage/current-source.htm
http://diyaudioprojects.com/Technical/Voltage-Regulator/
The first site there includes some power calculations, as well.
Thanks all.
