An RC filter with a 2ms time-constant can be made from any combination of R and C that multiply together to give 2ms. For example if you use 10kΩ for the resistor than you would use a value of 2ms/10k = 200nF for the capacitor. The value you use for the resistor depends upon the impedance of the circuit where the filter is placed. You want R to be a least 10 times smaller than the circuit impedance on the output (load) side of the filter and at least 10 times larger than the impedance of the source on the input side of the filter.perfect! but i don't know how to design that filter !
by Jake Hertz
by Duane Benson
by Jake Hertz
by Aaron Carman
