OK, so the individual cell Vf is 2v with the higher concentration.
This is actually more of a "wall" than I expected. Pretty good as a Zener diode
Back to the power dissipation thing. With the higher concentration of electrolyte and using 5 cells, with the 10.4A flow, you're dissipating 20.9W per cell for a total of 105 Watts (rounded off). You still have a pretty severe power (heat) dissipation problem.
You need some way to get rid of that heat.
You won't be able to use a single radiator for the five individual cells, because there would be a current path through the electrolyte streams when they merge.
Oh, and stainless steel is great for it's corrosion resistant properties. Unfortunately, it's a lousy conductor of electricity (heat, too); it has 15x to 22x the resistance of copper.
