Sooo.. I am a complete novice, in way over my head.
I got pretty excited by the ability of PVDF to generate a piezo electric effect.
Details here:
www.media.mit.edu/resenv/classes/MAS836/Readings/MSI-techman.pdf
I was looking to use the pvdf film as a simple switch. However, it seems that that the output of this switch may be unreliable due to low pass filter effect. At least, so I was warned.
Can someone help me understand this: It is suggesting the need for a huge Giga Ohm impedance on the input.
However, here: www.media.mit.edu/resenv/classes/MAS836/Readings/MSI-techman.pdf
Page 43, ff: it suggest that the pvdf films are suitable for piano keys which is my intended project.
This
again suggests problems with detecting strikes, or low frequency events.
So. I'm all confused. Are 3mm x 12 mm film segments suitable for detecting a keystrike/deflection?
What should I do about the impedance, if I wished to incorporate this into an arduino project?
Thanks a ton in advance.
Details here:
This
