timrobbins
- Joined Aug 29, 2009
- 318
Marshall - he doesn't have fets or opamps. For whatever reason he only has those part groups - and even then I doubt he has much variety per se - so it is all a bit hypothetical I suggest anyway.
If your panel's Isc is less than the float current, and the averaged self-discharge current then connecting a low powered PV panel without a controller is somewhat ok. However, without doing the sizing assessment, it is easy to cook an expensive battery due to overvoltage.
There are a huge number of simple opamp based controllers around to utilise without us dreaming up yet another example. The simplest use a series FET with the battery, to effectively pwm the battery voltage to be acceptable (assisted by the time response of the battery voltage).
Ciao, Tim
Ciao, Tim
