burger2227
- Joined Feb 3, 2014
- 194
It appears that the Dim and Gnd legs are on the same copper so the chip needs to be moved to the left a bit. I'm thinking that the Dim pin low turns it off. No connection may turn it off too, but it may flash on for a bit at startup.
What would I do? Do everything on a breadboard. They do make small grasping clips that can grab ahold of those small chip pins too.
http://www.ebay.com/itm/10-pcs-Small-Test-Clip-for-Multimeter-Lead-Wire-Kit-Repair-Tool-5-color-/230998564086?pt=LH_DefaultDomain_0&hash=item35c8965cf6
Soldering should be a one time thing based on the limitations I have seen for many components. Radio Shack has a nice battery operated iron that I use for delicate soldering jobs.
