hello everyone /I want to transfer the reading of a pt100 into voltage so i can read it from an analog input , I used a transmitter this one
https://www.amazon.com/Uxcell-4-20mA-Temperature-Sensor-Transmitter/dp/B00GN6X25U/ref=sr_1_fkmr0_1?s=industrial&ie=UTF8&qid=1486983398&sr=8-1-fkmr0&keywords=PT100+Temperature+Transmitter+Sensor+-50+~++150C+OUT+4-20mA+Power+24VDC
but there is no change in amps or voltage in the output of this transmitter ?
what should i do in this case , or is there a better way to change the reading of the resistance of pt100 into voltage and then into temperature ?
thank you in advance
