Protection Circuit for 12V LED Lamp
Kamy_King
Joined May 4, 2011
5
I have a circuit that uses a power MOSFET to control the state of a water valve. The valve is hit with an initial 50 VDC pulse (1.5 ms) to ensure that it opens, and then the voltage is dropped to 10 VDC to maintain the valve open.
I would like to use the same MOSFET output that controls the valve to control a 12 VDC, 41 mA LED lamp (that would show the status of the valve). I am looking for the best way to protect the LED lamp from the initial 50 VDC pulse. Would it be okay to simply use a resistor and a zener diode?
Any suggestions would be greatly appreciated.
17,498
You could put a capacitor in parallel with the LED, so that a pulse gets shorted to ground around the LED rather than through it. The LED wouldn't take any current until the cap has absorbed a bit of the initial charge. The cap will need a discharge path - not just the LED - so that it is fully discharged when the valve is off. You don't want repeated "on" pulses before the cap has a chance to discharge.
Or why not just send the LED current through the MOSFET also?
t06afre
Joined May 11, 2009
5,934
Please tell us more about the LED. 12 volt sound strange if it is a discrete LED. Zener and resistor might work. Perhaps also an inductor can block the 50 volt pulse.
Kamy_King
Joined May 4, 2011
5
Thanks for sharing your ideas. I would like to send the LED current through the MOSFET. However, the 50 VDC pulse is wired to the same output. I have attached a schematic of the relevant parts of the circuit.
I am looking to use one of those LED light stacks. A single lamp at 12 VDC uses around 40 mA.
Thanks again for your help.
Wendy
Joined Mar 24, 2008
23,421
Why not put the LED/resistor/zener circuit across the solenoid? It would be much simpler than making a separate MOSFET circuit, and work as well. Most low power LEDs max out at 20ma, and if you really want long life design for 10ma. They will still be plenty bright.
