Then for safety's sake it would be unwise to tackle construction of a DIY controller, especially without full knowledge of the joystick and valve ratings/properties.I'm afraid I'm a novice to this area and I would not know where to begin.
In the article I linked to the typical current is quoted as 0-2.1A.I do not see the current requirement being more than an amp or so for pilot operated valves.
In the circuit I posted that is averted by connecting the two ends of the pot together. The resistance then varies non-linearly with wiper rotation, albeit symmetrically about the centre (off) point; but the non-linearity can be an advantage in that resistance changes more slowly near the off point, giving a 'soft start' effect to the ram movement.The problem or thing that has to be addressed is at present the centre off represents the 50% point of the supply across them.
Max.
An amp or so!In the article I linked to the typical current is quoted as 0-2.1A.
Right . Further research (on Bosch Rexroth valves) indicates the solenoid resistance is ~2 Ohms cold, 3 Ohms hot (up to 150C!) and that max allowable current is 2.5A, so current-limiting (straightforward to do) would need to be added to my bare-bones circuit.An amp or so!
by Duane Benson
by Jake Hertz
by Duane Benson
by Duane Benson
