At some point we all have a power supply to test. I built this piece of test equipment specifically for the job.
Basically all it is is a constant current source, nothing more. I was very paranoid about the transistor / heat sink dissipating 150W (its max rating), so I used the metal lid from the Radio Shack box to make a heat shield.
While I allowed for the option, I have not installed heat sink fans. I'm going to wait and see how badly they are needed first. It is a very good idea not to have the heat sink on any valuable surfaces like the counter top or kitchen table when you are using this gadget full bore, lest you leave scorch marks.
The modulation input will allow you to vary the load current with a square wave, you can check the two current set points with an oscope on the DVM output. This will allow you see how good the power supply under test really is.
Complete drawings, including mechanical drawings, are in the attached zip file.
One innovation, which will soon be released as a separate Completed Projects entry, is the X4 AA battery bucket. It is super glued in the enclosure to keep the batteries put and stable. As an added bonus, I taped some spare 10A fused underneath the batteries. See images 2.JPG and 3.JPG if you want to see how I did this.
Frankly the panel meter was a disappointment. It is not very stable, and not real accurate. I will use it, it will get me in the ballpark, but for precision I will use external metering if I feel it is needed.
