Problem with transisor current
qbvbsite
Joined Jun 29, 2010
25
Hey,
I have been learning about basic electronics for a few weeks (again) and currently i'l working with transistors. I created a very basic circuit in a simulator and got the exact expected result (photo below). I then went ahead and bread boarded the circuit and didn't get what I was expecting. I was wonder if someone could look at it for me?
Simulated Circuit
I get the pretty much the expected result.... 1.5mA into Base and 115mA on the LED
Bread Board Circuit
This I do not get what I see on the simulated circiut.... I get 1.7mA in the Base (i'm fine with this).... but I only get 3.8mA to the LED
Can anyone explain why this happens? do I have something wrong?
Parts
- 2x 1.2v AA Battery
- 1K resistor
- PN2222A Tranisitor
- Red LED
Thanks,
--James
ScottWang
Joined Aug 23, 2012
7,400
1. How is the LED spec Vf, If? (The basic spec of LED)
2. You should series a resistor between LED and C of Q1, that is the limitation resistor protection the LED.
R = (2.4V - V_Led - 0.2(Q1 Vce)) / I_Led
3. Redo the labs again.
Audioguru
Joined Dec 20, 2007
11,248
You should not go near a transistor without looking at its datasheet.
You connected the transistor UPSIDE DOWN!
Then its collector and emitter are backwards.
If the circuit was wired correctly then the LED would have burned out in a moment because its DATASHEET says so.
qbvbsite
Joined Jun 29, 2010
25
Hey,
Thanks for the tip... I just checkout the spec sheet briefly just clearly miss read the pins. Its working much better now... with no load now it goes from 16.7mA base input to 660mA on the collector. I'm guessing that I get about 39x gain. But when I reduce the current on the base to 1.5mA i get 230mA output on the collector which is like 153x gain... why is this? Also on either circuit if I put a LED on it the collection current drops to about 34mA.... Add a 22ohm resistor between the collector and the LED it drops to 16mA... I'm guessing the LED automatically limits the current to around 34mA? but its better to limit it with resistors to ease the load on the LED is this correct? sorry if this seems like beginner stuff, but I am just starting :).
Audioguru
Joined Dec 20, 2007
11,248
You forgot to tell us which transistor you are using and which LED so we can see their spec's on their datasheets.
Most little transistors work well up to a collector current of about 100mA but the hFE drops with more current. At 230mA your transistor had a current gain of 153 and at 660mA it gain dropped to only 39 which is normal. I suspect that your battery voltage is dropping which is limiting the current, measure its voltage when the transistor is conducting 660mA.
The current drops when you connect an LED between the collector and the positive supply because the transistor does not have enough base current for it to be a switch. The datasheet for nearly every transistor shows its low "saturation voltage loss" which is when it is a switch. Then hFE is not used and the base current must be 1/10th the collector current. But some transistors will have more current gain.
If you use the correct amount of base current then the LED will quickly burn out if it does not have a current-limiting resistor.
Most 5mm diameter LEDs are spec'd at 20mA. 30mA or 40mA is their maximum allowed continuous current. So of course you need a resistor or circuit to limit the current.
qbvbsite
Joined Jun 29, 2010
25
Hey,
The transistor I'm using is PN2222A Transistor (Generic NPN Transistor). As for the Red LED I'm not exactly sure as its from components I orders quite some time ago. I tried reading the Transistor datasheet and I currently have no idea what all the values are :S. Lots to learn I suppose.
--James
qbvbsite
Joined Jun 29, 2010
25
I'm guess these are what the symbols mean:
Ic = Current on Collector
Ib - Current on Base
Vce - Voltage on the Collector and Emitter
Also when voltage on the Collection and Emitter is above 0.3v will this then become a saturated switch and anything below that wouldn't work? Is this basicly the "junction forward voltage"?
In their test conditions lets say I do what a Ic of 500mA with a Vce of 10V... I would have to put a Ib of 12.5mA? Or if I wanted a Ic of 150mA with a Vce of 10V I would need a Ib of 1.5mA?
Thanks for all the help it's quite useful.
--James
Audioguru
Joined Dec 20, 2007
11,248
Ic = Collector Current
Ib = Base Current
Vce - Voltage between Collector and Emitter
Yes.
Also when voltage on the Collector and Emitter is above 0.3V will this then become a saturated switch and anything below that wouldn't work? Is this basicly the "junction forward voltage"?
It is not a junction forward voltage. Instead it is when the transistor is turned on hard so that its collector to emitter voltage is as low as it can go, like a turned on switch. When a transistor has plenty of collector to emitter voltage then it is a linear amplifier, not a saturated switch.
First of all then the power in the transistor will be 5W and it will smoke and burn. The hFE at 500mA is 40 to maybe 100 so the base current will be 5mA to 12.5mA. You must design a circuit so it works with any hFE of the transistor.
Then its power is 1.5W and again it will smoke and burn.
The hFE at 150mA is from 100 to 300 so the base current will be from 0.5mA to 1.5mA.
qbvbsite
Joined Jun 29, 2010
25
Hey,
Thanks for all the help. I have ran a few tests to see what kinda of current I get they are as follows:
V1: 2.55v
LED1: Generic Red LED
Q1: PN2222A
R1: 1K
R2: 1K
Test #1 - Complete Circuit with All Resistors and LED
- Base: 1.7mA
- Collector: 0.6mA
- Emitter: 2.5mA
Test #2 - Removed R1
- Base: 20mA
- Collector: 0.6mA
- Emitter: 20.7mA
Test #3 - Removed R1 & R2
- Base: 20mA
- Collector: 29mA
- Emitter: 48.6mA
Test #4 - Removed R2 & LED1
- Base: 1.5mA
- Collector: 220mA
- Emitter: 220mA
Test #5 - Removed R1, R2, & LED1
- Base: 20mA
- Collector: 660mA
- Emitter: 660mA
I few questions I have:
- Will the Emitter pretty much equal Base + Collector?
- In Test #3 why when adding the LED do I only get 29mA when 20mA is on the base? Is the because the LED has a DC forward current of 30mA?
- In Test #2 the Collector current doesn't change from Test #1 is this because of the 30mA forward current of the LED?
I know some of the test are not how you would make a circuit and will probably burn out component is connected to long but there are just tests to better understand the working of the transistor.
Thanks Again,
--James
Audioguru
Joined Dec 20, 2007
11,248
Of course.
The LED does not limit its current. Your circuit must limit the current.
The maximum allowed current in the LED is probably 30mA. Any more current will burn it out. I think the collector current is 500mA or more and the LED burned out.
I think your current meter cannot accurately show the current when the voltage in the circuit is this low.
Oh, you are using a breadboard whose contacts cannot conduct much current.
I think you removed R1 (the base resistor) not R2 (the resistor that limits the collector and LED current).
The power supply is 2.55V. The red LED has a voltage drop of about 1.85V. The collector saturates at about 0.1V when R2 limits its current.
Then R2 has (2.55V - 1.85V - 0.1V)= 0.6V across it and Ohms Law calculates the current in the resistor, in the LED and in the collector to be 0.6mA.
qbvbsite
Joined Jun 29, 2010
25
Hey,
Thanks for the answers.. I still don't understand when adding the LED I'm only measuring a fraction of what the current is. I'm gonna start to read more of the DC book found on this website which will hopefully clear this up. Thanks again for all your help, I have learned much from this thread.
--James
Audioguru
Joined Dec 20, 2007
11,248
When you add the LED to the collector then the collector voltage drops about 2V from 2.55V to about 0.6V. Then its current gain is a little less than with 2.55V Vce.
But something is wrong with your measurement because your collector current dropped much too low. I think the contacts on your breadboard are intemittent or the connections of your current-measuring meter.
