takao21203
- Joined Apr 28, 2012
- 3,702
You'd eventually encounter C compilers are a finicky business.
Try to make the old Aztec C working on the 68000.
-The installation is broken you need to replace a small file. For instance you can get something suitable from a SDK CD.
-It is a CLI compiler. So you need a text editor as well. And you need to write small scripts or you have to type a lot each time you compile.
-One small mistake, and the system will need a reboot (which takes a few minutes).
-There is no such thing as PDF files on that machine or comfortable task switching.
-The examples from the original manuals are not written for the Aztec. They don't compile. In order to make them work, you need to add many typecasts. There are also blatant errors you need to find these as well.
After a day or two, if you are eager, you can really make some C sources working. Amazing.
If you went through this without any kind of tutorial, you will not have so much difficulties with modern C compilers. You will have at least some idea what could be wrong. Zoikes!
Also you'd have to know where to get the floppy images on the internet. It is all available, just not so easy to find.
