Hello AAC, I am hoping to get some help getting a 74193 counter IC working properly. After a momentary High is put on the clear pin, the Q-outputs will all go Low properly, but the Q-outputs do not increment in sequence, as they should. The binary count output varies; it will sometimes increment from a 1000 to a 0010, or from a 1000 to a 1100, and then to a 1110. I have a bunch of these 74193 counter ICs, and have used them before without problems, but now I'm having trouble. I'm not using the preset pins (I have them grounded). I have the load pin tied high, and a 555 Timer going to the count-up pin, (count-down pin is tied High). For now I was just trying to get it to count from 0000 to 1111. Thanks lots.
