Did you read post 17? Are you sure the 555s have the same part number? All 555s are NOT equal.<snip>But why would my proto board work perfect and reset instantly but not the PCB? This is confusing me!same parts same layout. LOL Thanks Jim
I thought about the LEDs. They will approach an open circuit as the voltage across them drops. I don't know if that voltage is high enough prevent adequate discharge of C1 or not.The only problem I have with the CMOS theory is the LEDs. Of course, I've been wrong before. Though thinking about it, a standard 555 should be a minimum of 15KΩ, which is pretty close to the 10KΩ value.
Maybe not so far off base after all.
Thread starter | Similar threads | Forum | Replies | Date |
Z | Prob with calculating Eigen Vectors using Augmented Matrix | Homework Help | 0 | |
prob with keil | Microcontrollers | 5 | |
D | help please technics amp small prob | General Electronics Chat | 3 | |
F | Thevinen Equivalent Analysis Prob | Homework Help | 3 | |
Z | Prob with understanding Bezier Curve Example | Homework Help | 4 |
