potentiometer wiper wiring??
simontheng
Joined May 12, 2011
4
HI guys, just want to check is there any potentiometer which has the the wiper pin at its last pin.
i have just screwed my pcb, i had put the wiper pin in pin 3 which is wrong!!! so is there any potentiometer that it's pin is swap?
beenthere
Joined Apr 20, 2004
15,819
I've never seen a 3/8ths or 9 mm pot that does not have the wiper as the center pin.
You now have an opportunity to discover the great utility of an Xacto knife in cutting foil traces so you can use 30 ga wire to rework the circuit.
