Ever notice how a lot of these type posts are usually from brand new members and they need the answer right then - as if the homework project is due the next morning?It is very similar to the one I showed in LEDs, 555s, Flashers, and Light Chasers. I suspect the OP has made it obvious this is for the real deal though. We need it confirmed.
What I love best about it is if I leave my calc on the desk at work (have one there and one at home) and someone picks it up to try and do a quick calculation.What!?! You don't like reverse polish! Who knew.
I did notice actually, quite annoying. Learning takes time... time takes patience... both of which are pretty much required for the AAC program to work for you. If you have no desire to learn, and no patience for learning, you should probably not be messing with things that require electricity, which can kill you. Is this the same person that wants a rice dispenser?marshallf3 said:Ever notice how a lot of these type posts are usually from brand new members and they need the answer right then - as if the homework project is due the next morning?
